  • 442 Vote(s) - 2.75 Average
Wireless intercom
I've picked up a cheapo digiteck wireless intercom, works ok for the money and can run off batteries alone or transformer, when its running off a transformer the caller unit has a 12v +&- wire, I think its more for a door lock but could this be used to open the gates on the CB24 board?
Sorry for all the thick questions. Rolleyes
marknjo Wrote:I've picked up a cheapo digiteck wireless intercom, works ok for the money and can run off batteries alone or transformer, when its running off a transformer the caller unit has a 12v +&- wire, I think its more for a door lock but could this be used to open the gates on the CB24 board?
If you are sure this is a switched output,
You need to wire this 12 v output to a suitable relay(12volt dc, into the coil terminals, normally marked up A1 and A2), run a cable to the control panel, on the relay use 1 core to the common, and another core to n/o. then at the cntl panel end, use the same 2 cores into open and common.
should work.....
carl.
Home IQ Wrote:If you are sure this is a switched output,
should work.....
carl.
Thanks Carl think I understand, as for the switched output, the handset indoors has a unlock button on it to push?.
should work.....
carl.
Any Easier option would be to use Our Handy relay Module DBR200 which are priced at £12+vat
I'm fitting all this kit this weekend so if I have any problems I'll phone Monday and get the relay Module DBR200 off you.
Fingers crossed everything goes ok. haha
All wired up and working fine with a halfords relay. Thanks guys for the help.
  GSM intercom DBElectric 1 2,342 17-06-2022, 12:30 PM
  Daitem intercom not working mikecymru 1 16,121 19-12-2020, 08:56 PM
Last Post: Andy
  AES DECT GSM Intercom landline dial programming manchester_sparks 0 16,650 18-03-2018, 09:02 PM
Last Post: manchester_sparks
  Daitem wireless intercom Mel1962 0 20,785 25-07-2013, 12:49 AM
Last Post: Mel1962
Shy Farfisa Intercom - Version PT 5160W Carolyn1Dickson 1 18,506 10-04-2013, 02:17 PM
Last Post: Blakey111
  Wireless Intercom Conflict B Gates 4 25,935 05-10-2012, 09:50 AM
Last Post: linda45
  Daitem d5731gb wireless intercom - Instructions needed Poppet 1 36,917 19-12-2011, 11:33 AM
  New daitem / logisty wireless intercom systems KIT SC902AU BarkerandGeary 3 31,261 18-10-2011, 09:31 PM
Last Post: alban gates
  Farfisa video intercom manual BarkerandGeary 2 19,195 12-07-2010, 02:17 PM
Last Post: BarkerandGeary
