10-11-2008, 05:31 PM
Mark
Fault has not repeated (YET!) since my original post. I have re set all the limits and turned up the force setting to 3/4 from just over 1/2.
I have just checked geometry and is as follows: A=12cm B=16cm
Motor is on the outer bracket hole, I have limits set so that gates open to I guess 95-100 degrees.
Does this sound Ok or should I change the position of the motor on the bracket from the outer hole to reduce the B measurement?
Ian
Ian
