  • 2 Vote(s) - 3 Average
Rigel 5 - second keypad stopped working
Hi there
I’m a bit baffled.  I have a Rigel 5 system with two keypads - one at the gate entrance on either side of two electrified motor driven gates
All has been working fine for 4 years without issue.  Until one day the keypad with the camera lost its configuration and required setting up again - which was done by out maintenance company.
A year later the same has happened with the second keypad which is an SRS DC60. It has been programmed and when a correct 4 digit code is entered it appears to go through the motions however doesn’t activate the Rigel to open the gates. Power is showing, the green light appears when the correct code is entered.
When using the other keypad with a correct code - that activates the gates as expected
What am I missing please ?
Both are configured as NO.  However I did spot that in the panel with the camera - common is empty however on the keypad not working - there is a common wire connection
Rigel 5 - second keypad stopped working - by HarefieldHse - 13-06-2023, 07:19 PM
  Rigel 5 , gates won't open Nameloc 4 4,045 04-05-2024, 12:41 PM
  Faac photocell stopped working Zeb Gulickx 2 1,205 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  BFT Rigel 6 stevew 3 1,712 29-08-2023, 08:39 AM
Exclamation Proteco Q60A stopped working xCO 0 1,023 19-06-2023, 01:03 PM
Last Post: xCO
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 4,367 02-12-2022, 02:51 PM
  Wired up but not working Ranch2 7 4,903 18-11-2022, 10:02 AM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 4,144 26-08-2022, 03:42 PM
  Faac 740 - stops working norberto 1 7,268 02-06-2020, 05:15 PM
Last Post: norberto
  Getting motors working together Rich123 0 7,159 22-09-2019, 04:44 PM
Last Post: Rich123
  Strange gate operation Rigel controller Philreghse 0 6,733 10-06-2019, 09:18 AM
Last Post: Philreghse
