  • 137 Vote(s) - 2.98 Average
Came gates stuck open.
Hi I wondered if anyone can help?
I have a set of came swing gates which have been working perfectly until today.
They open fine on the fob or internal switch, but will not close automatically. When you press the fob to close them they seem to move 6 inches to close but then 're open. I have disabled the photo cell and have even changed the wiring around on the arm motors to see if they will close (which they do), but then obviously won't 're open, the pcb is a za3.
I appreciate any help
Thanks in advance Martin.
that could be issue with power force or problem with capacitors
1 )to set power force higher you have to move conector on transformator from position 1 to 2,3,4, max
2)change capacitors for new one if older then 4 years
regards
(07-05-2018, 07:37 AM)Ring8180 Wrote: Hi I wondered if anyone can help?
Hi Martin,
I seem to have the same problem, any chance you can share what was the issue?
Just to add to the detail, in my case i eliminated all sensors and even took the link to the leaf out. I also reversed the brown and black wires and i could see that the motor turns with every press of the key but when it supposed to turn the other direction it doesn't, in fact it rotates in the same direction as before, however this could be the residual charge of the capacitor, not sure if the last bit is valid, can't say i know enough about the electrical arrangement.
Tested the capacitors and perfectly fine: 15.8uF on a 16uF rated capacitor.
Regards.
Hi Martin,
Regards.
Hi Androidus,
My problem was the wires into the Pcb had worn and were shorting.
I originally changed the capacitors and it made no difference.
It was only when I took the cover off the pcb i noticed the outer casing on two wires had worn
I hope you manage to sort it
Martin
P.s if you do manage to sort it, perhaps post on here
What the problem was, that way it may help someone else.
(30-01-2023, 03:14 PM)Ring8180 Wrote: Hi Androidus,
Martin
Hi Martin,
All is fine again, it was one of the sensors. In my case when i said i eliminated all the sensors for troubleshooting i didn't put a jumper where i should've done. Anyway, as Sam mentioned reduce the board to its basic function and then check its functionality.
(14-02-2023, 11:22 PM)Androidus Wrote: Hi Martin,
Thank you for clarifying Androidus Smile
  Nice MC824H gate stuck open Markp80 1 197 13-05-2024, 02:32 PM
  Rigel 5 , gates won't open Nameloc 4 4,024 04-05-2024, 12:41 PM
  Gates tripped Phil.c 3 449 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 469 18-02-2024, 06:29 PM
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 1,947 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 9,082 07-01-2024, 07:11 PM
Last Post: Simon NW
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 2,025 02-10-2023, 09:20 AM
  Nice Gates not closing StuL 1 1,785 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 9,806 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Holding the Gate Open mgb 1 4,093 11-07-2023, 01:35 PM
