  • 179 Vote(s) - 2.75 Average
Gate Controls/Indicators 200m from Gates
2) Gate open light (240v)
Morning!
I hope this helps.
EasyGates.co.uk
EG Direct - Trade only
Thanks Ryan.
The other problem we have is that the gate is out of sight from the house from  Although it's only 200m in a straight line, it is roughly a 500m walk to get from the house to a point where you can see whether the gate is open or not.
That is quite a distance.
I agree with you mate, it will be difficult to get a strong signal with that distance
Hi, have you possibly tried using a designated Ariel to boost signal strength.
#9
#10
  Gate mobile phone ‘relay’ jam_rs 1 150 13-05-2024, 02:37 PM
  Nice MC824H gate stuck open Markp80 1 170 13-05-2024, 02:32 PM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 28 17,792 10-05-2024, 08:27 PM
Last Post: Nemen3242
  Rigel 5 , gates won't open Nameloc 4 4,006 04-05-2024, 12:41 PM
  Gates tripped Phil.c 3 437 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 461 18-02-2024, 06:29 PM
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 1,904 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 9,061 07-01-2024, 07:11 PM
Last Post: Simon NW
  Nice Gates not closing StuL 1 1,764 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 9,795 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
