  • 140 Vote(s) - 2.55 Average
BFT Deimos A600 (HAMAL control board) troubleshooting
Hi you all,
I'm writing from Italu.
After facing some troubles I succeeded to install a BFT Deimos A600 engine for a sliding gate.
It replaces an old BFT LEM.
Photocells are CAME Delta E (the existing ones, not replaced).
After having installed and configured the engine turn ON the power and ... it doesn't work.
LEDs are all OFF but:
Power: ON
BAR: ON
PHOT: ON
SWC: ON
SWO: ON
STOP: ON
DIP switches are at default but the one that configures the direction of the opening, that I reverted.
I don't use SAFE inputs for photocells.
Photocells links are:
Engine 51 <-> photocells 10
Engine 50 <-> photocells 11
Engine 70 <-> photocells C
Engine 72 <-> photocells NC
I ran the autoset, the gate didn't move at all, the engine never ran; at the end the SET led is off, the ERR led is slowly blinking.
According to BFT manual this means:
Photocell test, Costa o Costa 8k2 failed
- Check photocell connection and/or logic settings
Thanks for any suggestions to fix the trouble.
Br
Enrico
Hello Enrico,
Can you tell me what is the reference written on the transistor: Q29
of your A600 (HAMAL control board) ?
Cheers
Taoz
  BFT Deimos BT A600 fault Error 10 Airbus330/300 5 6,843 06-03-2024, 11:59 AM
Last Post: GateOpe
  BFT deimos smoke from board stanli200188 1 1,102 05-03-2024, 04:17 PM
  Thalia P - Wireless control board module mathewnorris22 1 2,930 02-03-2023, 03:17 PM
  Er 10 code on RIGEL 6 control unit Eddiew 1 2,861 05-01-2023, 11:53 AM
  LED on control board is off Arthur_k99 2 10,507 14-04-2020, 01:41 PM
  BFT Deimos Ultra remote problems shaggy 1 11,375 01-05-2019, 09:43 PM
Last Post: ok.dude
  BFT Deimos Ultra BT A 600 + Tbox ok.dude 1 6,751 30-04-2019, 09:32 AM
Last Post: ok.dude
  BFT Deimos - How to fit a GSM Switch. MyGatesDontWorkSoGood 0 6,212 02-06-2018, 04:46 PM
  BFT Aires P Board burned Anomalia 0 6,894 15-02-2018, 10:53 PM
Last Post: Anomalia
  BFT LIBRA CONTROL PANEL neilskeates@gmail.com 7 23,350 16-01-2018, 05:13 PM
