  • 128 Vote(s) - 3.23 Average
Q36A Proteco Gates
Firstly I apologise in advance for being an electric gate numpty! Build a house no problem! program electric gates AHHHHHHH
I have the shark double gates which is controlled by the Proteco Q36A Board which im told is very similar to the Q60A.
After trying to set up a GSM mobile controller the gates seem to of set back to default and can I get them to open and close properly !!!
Looking from the rear the left hand side one lets call it leaf A - MOTOR 1 at present sets off after leaf B - MOTOR 2. problem is Leaf A needs to close first.
On the controller once in parameters N1 is leaf A MOTOR 1 WORKING TIME 0-99 which I assume is the amount of time the motor runs (simple enough)
N2 the same Motor 2
I keep these the same at 19 seems to take them all the way back
F1 - Motor 1 Torque 6-19 which I set higher than F2 Motor 2 torque on the hope it would close quicker and therefore take over! it doesnt
Fr - Motor Power During Deceleration 6-19 (Havent a clue what she does!)
t5 - Motors closing differential time delay 0-99. I set this to 0 as dont want them to delay closing?
All the other settings have no relevance and im not sure any of these actually control which leaf closes first?
I then have some sub menu's ie dE - Default where it does then jump to Functions, Advantage Motor Defaults and Wheeler Drive Defaults but im lost at this point!
Anyone any idea?
  Rigel 5 , gates won't open Nameloc 4 4,045 04-05-2024, 12:41 PM
  Gates tripped Phil.c 3 479 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 483 18-02-2024, 06:29 PM
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 2,001 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 9,109 07-01-2024, 07:11 PM
Last Post: Simon NW
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 18,156 26-09-2023, 05:32 AM
Last Post: max666
  Nice Gates not closing StuL 1 1,816 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 9,836 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
Exclamation Proteco Q60A stopped working xCO 0 1,023 19-06-2023, 01:03 PM
Last Post: xCO
  Came gates stuck open. Ring8180 7 17,403 23-02-2023, 01:08 PM
