  • 266 Vote(s) - 2.82 Average
Daitem SC9200AU Controller to Nice MC824
I've wired the controller up as described in your tech sheet but the controller only opens the gate. I don't have the gates auto closing so would like to be able to close them using the handset. Is this possible?, cheers.
Ok, figured out how to get it to close. I swapped the wire from terminal 14 from "open" to "PP". The gates now open and close ok but the display always indicates the gates as closed. Is there any way to correct this? Cheers.
The daitem is only designed to open a gate, then automatically close it "if set on the gate panel" that's why it cannot tell if the gate is open or closed,
(10-10-2014, 12:59 PM)Shropshire fella Wrote: Ok, figured out how to get it to close. I swapped the wire from terminal 14 from "open" to "PP". The gates now open and close ok but the display always indicates the gates as closed. Is there any way to correct this? Cheers.
  nice robus D400 smartphone control YOSH 1 1,189 05-03-2024, 04:45 PM
  Nice MC800 Wiring issue Adamzsite 2 1,162 05-03-2024, 04:37 PM
  nice robus troubleshooting tarmongaidon 7 17,542 30-01-2024, 05:19 PM
Last Post: hasanova
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 2,187 04-01-2024, 10:06 AM
  Nice Robus RBA3c Wifi Relay Switch Wiring denis 1 2,634 01-11-2023, 09:45 AM
  NICE MC800 Factory Reset bg148 5 3,825 12-10-2023, 01:11 PM
  Nice MCA1 stuck open after stop command Khooke 1 2,892 25-09-2023, 10:47 AM
  Nice transmitters - compatibility Noghar 6 6,998 10-10-2022, 10:02 AM
  NICE MC82H - connecting maglock grangerd 3 5,100 10-10-2022, 09:40 AM
  Nice Robus Don't Auto Close!!!! Ali_1982 1 4,465 03-08-2022, 02:23 PM
