02-04-2026, 05:50 PM
Just thought I would share this about NEW CAME REMOTES and COMPATABILITY. I bought 2 new TOP44RBNs from a French company that on the web stated that were a 'replacement' for the earlier TOPD4RDSs and was told they were totally compatible and the new could be connected by direct transfer from the old. After a lot of faffing about the 44s would not link and the lights didn' t do what they said they would do either on the web site or indeed on the instruction sent with the products. A very helpful Riley from Came UK advised that the two could not be synced and the 44s had to be connected direct to the mother board in the power unit. OkĀ - easy to take off the front cover, then to work out which button to press as the instructions on line are misleading. It is in fact 'ent' on the right of the 'go right' button just below the little screen. You select 'user management' by clicking right then 'ent' then 'new user' ent which produces a code running accross the scree - let it get about 75% along and press the left hand top button on the new remote, DONT HOLD it. then 'esc' and you are good to go....
