  • 18 Vote(s) - 2.89 Average
Ditec sliding gate opener N/W.
Hi, I'm trying to repair a ditec gate opener possibly around 20 years old. It stopped working, however when pressing the remote button, the 2 leds come on showing its receiving the signal. Zener diode 1 and 2 were overheated and 1 wasn't working. I've replaced them but it's still not working, no clicking of relays, just the 2 leds coming on. Ditec tried a few things when I took it to thier workshop but they can't help. The circuit boards are no longer being made. Large white capacitor is good as are the 3 micro switches.
Any help appreciated.
https://ibb.co/Tq1DyYZy
https://ibb.co/bMkLCpFV
https://ibb.co/gZ7fW00Q
https://ibb.co/0pWQVRjF
https://ibb.co/3m93DDTL
https://ibb.co/1fZKyRJq
https://ibb.co/KcmbT8qj
https://ibb.co/60jkM9Hj
https://ibb.co/sdMMFndN
https://ibb.co/Y7FhVFwG
The two LEDs only confirm the receiver is decoding the remote; they do not prove the logic is issuing a run command. With power on, measure the DC voltage across each relay coil while pressing the remote. If it stays at 0 V, trace back to the relay-driver transistor and its base resistor from the control chip; if it rises but the relay does not click, suspect the coil or a dry joint. Since the zeners overheated, also check that the low-voltage supply rail is not high or collapsing.
  Ditec swing gate openers kioni 1 28,194 09-09-2015, 10:38 PM
Last Post: thm
  Ditec Cubic6 TriQpilot 0 10,748 26-08-2014, 02:57 PM
Last Post: TriQpilot
  DITEC sliding gate motor cuts out on opening only Peter 0 10,607 11-08-2014, 01:37 PM
Last Post: Peter
