  • 8 Vote(s) - 2.38 Average
Clemsa 16.1 board
Hi all,
         I'm working with a Clemsa 16.1 control board and I'm trying to understand the function of the “Entrada Auxiliar” terminals. I believe it translates to “Auxiliary Input,” but I'm not sure if this is the correct place to wire the photocell sensors. Can anyone clarify?
Clemsa 16.1 https://clemsa.es/wp-content/uploads/202...LACION.pdf
CAME DIR 10 photocell https://device.report/manual/14127270
The Automatic gate oprator for swing gates: https://fastgateopeners.com/store/media/...manual.pdf
I have not worked with this control panel before, however from looking at the wiring diagram and using some google translate, I would assume the photocell connections are going to be under the SEGURIDAD section.
The middle terminal of the three is the common input, the terminal to the left if the normally close input (photocell only works in opening manoeuvre) and the terminal to the right is another normally close input (photocell only works in closing manoeuvre). Why I say this is because SEGURIDAD means security, ABRIR is open and CERRAR is close (according to google translate).
The Entrada Auxiliar looks like a normally open input, this would not be used for photocells for safety.
I hope this was useful.
Many Thanks,
Aiden.
  PROTECO Q60S BOARD DHOB123 0 9,274 02-08-2017, 10:52 PM
Last Post: DHOB123
  Board showing red dot when transmitter pressed, not opening though SamuelWestwood 1 12,563 13-05-2016, 10:49 AM
