  • 14 Vote(s) - 2.5 Average
LCA 70 safety issue
Please advise,
I have a Ditec LCA 70 control panel with a safety issue "1-8" flashing
The following is what I have tried to resolve this issue
Checked the Prastel sensors for alignment, beam lit on transmitter and interupted when I cover the receiver Ok
Put new batteries in the receiver (Voltage ok)
Swapped both Prastel transmitter and receiver for a spare pair I had, cannot remember why I ended up with spares but the same fault showing
Put a jumper between com and 8 in the control panel to take out the safety circuit, gates work ok.
I'm not an electrician so in order to check the cabling between photocell com and NC I ran a new pair of wires photocell to control panel, still got the fault
Have I missed something? could the issue be in the control panel circuitry?
Thanks for any help
(13-08-2025, 11:49 AM)cully Wrote: Please advise,
Thanks for any help
It could be a possible board issue have you metered the voltage at the output on the board which the photocells are wired to to see if they are getting adequate voltage?
  Bininca photocell wiring issue Hsj 1 7,822 22-03-2024, 12:48 PM
  Safety Edges Jaddis 1 14,788 30-03-2022, 02:02 PM
  Swing gate safety edge Forum Flyer 1 17,766 17-03-2020, 10:16 AM
  Safety bar Jan Hinks 1 37,068 27-10-2014, 03:31 PM
Question Electric Gate Safety Poll easygates 0 23,297 11-04-2012, 10:23 AM
  EGD and ASO 2nd Gate Safety Conference easygates 0 22,545 05-03-2012, 03:40 PM
Question Electric Gate Safety Issues easygates 2 33,516 23-06-2011, 11:27 AM
