  • 24 Vote(s) - 2.67 Average
Fuse keeps failing
The 1.6 amp fuse on my Nice Robus 600 logic board fails as soon as I replace it. Any suggestions on how to diagnose the problem or what could be causing the fuse to blow?
(07-03-2025, 08:04 PM)kite420 Wrote: The 1.6 amp fuse on my Nice Robus 600 logic board fails as soon as I replace it. Any suggestions on how to diagnose the problem or what could be causing the fuse to blow?
Thank you for your message.
I would personally try and take all the connector blocks out that are going to your accessories at the top of the panel. Try putting a new fuse in and see if this blows, it could be back-feed from an accessory causing the issue.
If it does not blow with everything out of the panel, try and plug an accessory in at a time until the blow occurs again.
  Nice LFAB occasionally failing open DaveHG 3 10,074 20-08-2025, 01:52 PM
  Nice Robus 250 HS Fuse Problem GLM 1 4,820 09-05-2025, 01:07 PM
  NICE 1500A Gate motor and new intercom - fuse blown Phantome46 0 9,368 19-01-2020, 03:37 PM
Last Post: Phantome46
Users browsing this thread:
