  • 37 Vote(s) - 3.11 Average
Mhouse sl10 not closing
Hi, I am wondering if anyone has any advise, my Mhouse sliding gate has developed an issue where it will only open. I can unlock it and move it to mid travel, using the remote or keypad it will only motor in the open direction, I can stop it but not reverse it, when it reaches the fully open pos’n the ecsbus lights repeatedly flashes 7times.
I’ve cleaned the board it looks ok(I think)
Wondering if I need a new cl1s board but would like to exhaust other avenues first.
Cheers
Mark
Hi Mark,
This sounds like a photocell issue. What is the ECSBUS flashing light emitting (count the flashes followed by a pause).
Mike
I replaced the controller and it worked for a few months. Then the other day my wife was opening the gate and it stopped.
It is a CL1S controller. Is wont operate at all now. The ECS BUS and the P1 P2 and P3 lights are all flashing rapidly. I cleaned the  control board with IPA, though there was no obvious debris on it. When the gate is powered still has the flashing lights and no other operations.
Totally stumped with this
(26-01-2026, 07:03 AM)Sosislord Wrote: I replaced the controller and it worked for a few months. Then the other day my wife was opening the gate and it stopped.
The BLUEBUS led is a diagnostic LED, when this fault occurs (when the gate will not close upon command) check this LED and count the amount of flashes before there is a pause.
If you can let me know this, I may be able to inform you of what the issue may be.
Many Thanks,
Aiden.
  MHouse Sl1 does not open v.ptohides 1 7,466 03-02-2025, 09:56 AM
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 9,375 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 11,871 30-01-2024, 10:35 AM
  Mhouse left gate blocking full open when initialising gates neil.conner 1 9,852 24-08-2023, 01:51 PM
  Mhouse SL1 won't close correctly Dartman 5 33,553 03-02-2023, 12:04 PM
  Mhouse WH2S not opening SamGate 4 15,985 10-10-2022, 09:46 AM
  MHouse SL10 closes, but doesn't open cambo 1 9,072 19-08-2022, 09:29 AM
  MHouse SL1-10 partial close NAT 5 18,371 30-05-2022, 09:15 AM
  Mhouse WS2 Gates not closing together pauln0301 1 9,147 13-04-2022, 11:18 AM
  Mhouse WG20 Alex74 1 10,563 04-02-2022, 11:05 AM
