  • 25 Vote(s) - 2.96 Average
Keypad only opens after change
Hi everyone,
I have a BFT ultra A600 thats been installed and set up a few years ago.  Some time ago my father asked an installer to turn on the automatic closing which they did.  It was rediculously short and after the gate closed onto my car as I was reversing I had enough of it and looked up how to turn the automatic closing off.
I was able to do that but when testing I noticed the keypad can only open the gate after the pin is entered instead of toggling between open and close.  I tried everything and whenever I enter the pin, the screen on the board says OPEN.
For now I've been using the remote which does toggle open and close as normal.  I've tried checked everything and can't figure out what setting to change so that it behaves back like a normal gate again with the keypad.  A few times I've been caught out as I arrive, open the gate with the keypad and can't close the gate.  Need to drive home to get a remote and come back just to close it.
Any help or guidance would be much appreciated.
(15-08-2024, 03:34 AM)koruki Wrote: Hi everyone,
I have a BFT ultra A600 that's been installed and set up a few years ago.  Some time ago my father asked an installer to turn on the automatic closing which they did.  It was ridiculously short and after the gate closed onto my car as I was reversing I had enough of it and looked up how to turn the automatic closing off.
Thanks for the message.
Is this a wireless keypad or is it hard wired? if it is hard wired it will be effected by the logic of the control panel. if it is wireless it will be effected by the means of programming into the control panel.
  Sub BT oil change wbryce 4 15,244 28-01-2021, 12:54 PM
Last Post: wbryce
  BFT keypad code not working VDPJ 0 6,110 25-05-2020, 03:28 PM
Last Post: VDPJ
  Altair-P gates now move in opposite direction with any change to wiring william.helsby 1 10,200 24-05-2020, 08:08 PM
Last Post: william.helsby
  ICARO + LEO B CBB : 12V power for keypad? tommysharp 5 28,510 17-02-2020, 02:24 PM
Last Post: Caesium
  Oil top up/ change Adrian55 3 20,136 10-07-2019, 10:33 AM
  Fitting a bft kit with rigel 5, photocells, keypad, loop detector help easygates 1 30,584 14-05-2010, 01:01 PM
Users browsing this thread:
