  • 31 Vote(s) - 3.26 Average
FAAC Configure 443Hz remote to open partially, pause and close
Hi all,
I just moved in and stay in a shared apartment with a FAAC Sliding Gate System.
Currently I have a 443Hz remote with 4 buttons that is able to open the gate fully, the gate will auto close in 10 seconds.
And there is a physical switch at a side door that will open the gate partially.
How can I find out the frequency and configure in the 443Hz remote to
- Open the FAAC gate partially
- Pause the FAAC gate opening / closing
- Close the FAAC gate
I suppose the frequency will be the same for opening partially, pause and closing the gate?
Appreciate if there is any information / clue that I can learn here or figure out
(07-08-2024, 11:40 AM)Ezylryb Wrote: Hi all,
You will need to program the remote through a step by step function.
Could you please provide the model number of the gate control panel.
Jake.
Jake.
Hi Jake,
I have the exact same issue with my faac 741 motor.
Can you guide me to program the remote to function as above?
thanks
Jake.
Hi Jake,
thanks
Hi thanks for the message can you confirm what remote you have and i should be able to advise from here.
thanks Prem
  FAAC 455 - FSWCL not lit? Joshuajkp 0 1,188 21-04-2026, 08:34 PM
Last Post: Joshuajkp
  FAAC 455D - wiring issues? jonah 6 5,282 20-02-2026, 06:30 PM
Last Post: jonah
  Faac 740D, Open further then limit, not closing emiel 1 10,391 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 6,450 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 6,928 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 5,093 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 5,150 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 13,532 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 9,111 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 11,038 13-11-2023, 11:58 AM
