  • 69 Vote(s) - 2.91 Average
Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help
#31
Hi guys,
I was wondering how the diagram would look like if you have 2 Nice gate motor on the DS-KD8003.
I am trying to get two gates running  Sad
Could somebody tell me how to set this up with only 1 COM port on de Hikvision.
Thanks in advance
(10-10-2022, 09:58 AM)j1000 Wrote: Hi Joe,
Many thanks for your and Sams help and apologies for any confusion.
I would like the gate to open which it currently does via my Hik-connect app and the indoor door station.
Connected via No and Com ( Outdoor doorstation) to Robus 600 (Sbs).
The robus remote does the same function. When i press the button the gate opens and if i press it again the gate closes.
The following is what I would like it to do in addtion to the above.
I would like to be able to close the gate via the Hik-connect app and the indoor station.
Currently what happens is that the gate attempts to close (when fully open) but it only moves the gate say 1m then it reopens. This is when I press the same button on my app which causes the gate to close.
Appreciate any advice.
NB: I am not sure if this has got anything to do with it but at the moment, when I press the 2nd button on the Robus remote fob, the gate gives a 1m opening. (Pedesterian access). I dont really need this function but I was asking if you thought this could be a problem.
Thanks again. Your expertise is most appreciated.
Thank you for coming back to us on this.
I would try firstly getting the fault to occur again, as soon as the fault occurs due to it being a time sensitive thing have a look at the control board inside your motor.
There will be a terminal block labelled as BUS, BlueBus or ECSBUS. Behind that terminal there will be an LED flashing, under fault conditions the LED will flash a certain amount of times and pause for one second, could you let me know how many times your LED flashes as this could give us some indication of what the panel may be suggesting the fault is.
  Gate mobile phone ‘relay’ jam_rs 3 6,487 Yesterday, 10:16 AM
Last Post: DialOpenUK
  Nice Gates not closing StuL 2 11,147 16-08-2026, 02:45 PM
Last Post: ArmaniDx
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 3 23,896 15-08-2026, 09:31 AM
  Came gate opener remotes Alexlambrook76 1 2,769 19-05-2026, 02:07 PM
  one gate partially opening - board failure ? kathome 1 2,182 19-05-2026, 02:06 PM
  One side opens erratically - both gate stops sheared?? bomitie 0 2,101 18-04-2026, 03:18 PM
  Gate transmitters intermittently working Nice MC824H solihul 1 3,953 28-01-2026, 10:17 AM
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 4,839 09-01-2026, 10:38 AM
  Help me identify this mystery gate opener alpha 5 9,833 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 4,728 11-11-2025, 04:41 PM
