  • 118 Vote(s) - 2.92 Average
BFT Sub R
Hi All
One of my sub units is not working properly and there is fluid in the box, so may have to look at replacing the seals or replace the motor.
I am a complete novice with these, so I wanted to ask if anyone has replaced the seals and if there is an assembly schematic available for the sub r.  Also are any specialist tools required.
hi, did you get anywhere with this? My sub r is leaking oil also by the seal?
(27-05-2018, 09:29 AM)Vaf888 Wrote: Hi All
No. Ended up replacing them both
