  • 228 Vote(s) - 3.41 Average
safety edge problem
Hi folks first time posting
I have a problem with a bircher safety edge on a set of steel gates the batteries are only lasting about 2 weeks causing control panel to go into fault condition (came ZLJ24) I suspect faulty transmitter any help would be appreciated
Regards Lee
I would first test all safety edges on the system. Disconnect them and test for 8.2kohm on each one. If this is correct then it will be either a battery issue on the transmitter or a faulty transmitter.
Hope this helps.
  RBA2 PROBLEM Andruelectricgates 1 2,963 09-05-2025, 12:40 PM
  Faulty Beninca RF transmitter for safety edge JKR2 3 5,064 26-07-2024, 10:20 AM
  GIBIDI gate motor closing problem davidcunningham 0 11,603 26-04-2019, 08:20 PM
Last Post: davidcunningham
