  • 21 Vote(s) - 2.52 Average
BFT Rigel 5 with with two electromechanical operators Swinging gate inherited from the previous home owner, left no clue of what it is  or what so ever.
are they still working?
They don't have limit switches, somehow increase the motor torque and slowdown time/show down torque works. I figured that increased Motor torque would amplify the effect of slow down effect, given the slow down torque set to maximum of 99. One thing I am not sure is the braking effect and open/close impulse. Manufacturer, for some reason, not willing to explain more about these effect to me.
  BFT Rigel 5 Talonfinger 0 116 26-03-2025, 12:07 PM
Last Post: Talonfinger
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 774 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 642 03-02-2025, 11:29 AM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 586 04-11-2024, 05:59 PM
  BFT Rigel 5 - Phot message robs999 2 1,401 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 1,517 30-10-2024, 12:54 PM
Last Post: Vaf888
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 1,490 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 1,578 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 5,769 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 1,081 23-05-2024, 06:35 PM
Last Post: Zhymke
