  • 146 Vote(s) - 2.88 Average
Faac fuse blowing? 7PCB452/455 Issue 05a
Hello!
We've only recently moved into an old house, which had electric gates installed. The gates just stopped working the other morning, no longer opening or closing.
I've done a full fuse sweep, and found there's a small 1a glass fuse blowing on the logic board of the control unit. See attached photo for the fuse that's blowing.
I've replaced it twice (same type as was already installed), but upon clicking the open button on my keys, that fuse immediately blows again.
Is that likely a sign of a blown control board, or something more involved?
Cheers!
Mark
Hiya. To quickly check your board. Remove all wiring between terminals 9 - 19. Then link out terminals 11, 12, 13, 14. Just daisy chain the wires together. Your are just linking out the stop and safety inputs. Give the gate an open command. If the fuse blows. Assuming you do mean the 800Ma fuse. The board may have shot it.
(14-06-2017, 05:29 PM)Russ1804 Wrote: Hiya. To quickly check your board. Remove all wiring between terminals 9 - 19. Then link out terminals 11, 12, 13, 14. Just daisy chain the wires together. Your are just linking out the stop and safety inputs. Give the gate an open command. If the fuse blows. Assuming you do mean the 800Ma fuse. The board may have shot it.
i think its worth to unscrew pcb mainboard and check how its look from behind , sometimes you can have some bugs sticked to it .
Best RegardsĀ
TomĀ
  FAAc xp20d wiring Neil Young 4 1,182 04-02-2025, 12:08 PM
Last Post: Neil Young
  FAAC gates out of sync TheDock 1 1,303 21-08-2024, 12:21 PM
Last Post: TheDock
  Faac 452 pcb board benner91 2 3,835 09-02-2024, 06:13 PM
  Faac photocell stopped working Zeb Gulickx 2 3,986 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  Genius JA592 issue fintaneduffy 3 2,569 19-01-2024, 09:58 AM
  FAAC E124 fault 05 allan@amtas.com.au 0 1,874 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 6,559 03-07-2023, 08:54 AM
  7pcb452/455 FAAC Alpin 0 2,468 23-06-2023, 03:19 PM
Last Post: Alpin
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 4,301 25-05-2023, 03:55 PM
Last Post: Kaala1
  FAAC Photocells mmc1977 3 4,537 02-05-2023, 12:37 PM
