Threads: 1
0
2) Gate open light (240v)
Threads: 0
0
Morning!
I hope this helps.
Threads: 1
0
Thanks Ryan.
Threads: 0
0
Threads: 0
0
19-06-2017, 03:47 PM
(This post was last modified: 18-10-2021, 08:08 PM by Hardee.)
The other problem we have is that the gate is out of sight from the house from Although it's only 200m in a straight line, it is roughly a 500m walk to get from the house to a point where you can see whether the gate is open or not.
That is quite a distance.
Threads: 0
0
17-10-2018, 07:33 PM
(This post was last modified: 28-06-2019, 10:43 AM by joe.)
(19-06-2017, 03:47 PM)Hardee Wrote: (31-05-2017, 11:37 AM)ADicksoen Wrote: Thanks Ryan.
Threads: 0
0
07-05-2019, 10:46 PM
(This post was last modified: 28-06-2019, 10:44 AM by joe.)
(17-10-2018, 07:33 PM)alleno Wrote: (19-06-2017, 03:47 PM)Hardee Wrote: (31-05-2017, 11:37 AM)ADicksoen Wrote: Thanks Ryan.
I agree with you mate, it will be difficult to get a strong signal with that distance
Threads: 0
1
08-05-2019, 09:16 AM
(07-05-2019, 10:46 PM)iamashleywilcox Wrote: (17-10-2018, 07:33 PM)alleno Wrote: (19-06-2017, 03:47 PM)Hardee Wrote: (31-05-2017, 11:37 AM)ADicksoen Wrote: Thanks Ryan.
I agree with you mate, it will be difficult to get a strong signal with that distance Hi, have you possibly tried using a designated Ariel to boost signal strength.
Threads: 0
0
14-05-2019, 11:05 PM
(This post was last modified: 28-06-2019, 10:45 AM by joe.)
Threads: 0
1
(14-05-2019, 11:05 PM)ArthurBrown Wrote: (31-05-2017, 11:37 AM)ADicksons Wrote: We do already have a GSM unit on the gate, but due to the very poor signal in this area, it is unreliable.
