  • 268 Vote(s) - 2.82 Average
Daitem SC9200AU Controller to Nice MC824
I've wired the controller up as described in your tech sheet but the controller only opens the gate. I don't have the gates auto closing so would like to be able to close them using the handset. Is this possible?, cheers.
Ok, figured out how to get it to close. I swapped the wire from terminal 14 from "open" to "PP". The gates now open and close ok but the display always indicates the gates as closed. Is there any way to correct this? Cheers.
The daitem is only designed to open a gate, then automatically close it "if set on the gate panel" that's why it cannot tell if the gate is open or closed,
(10-10-2014, 12:59 PM)Shropshire fella Wrote: Ok, figured out how to get it to close. I swapped the wire from terminal 14 from "open" to "PP". The gates now open and close ok but the display always indicates the gates as closed. Is there any way to correct this? Cheers.
  Nice RB600 - Automatic close fail and opening issues P100D 1 796 30-09-2024, 02:43 PM
  Nice robus not closing Dantay 1 1,094 27-09-2024, 10:17 AM
  Nice Walky on 24v dman99 1 1,212 12-08-2024, 03:54 PM
  Can a Hormann Bisecur learn a code from a Nice ON2E? ? Noghar 1 2,066 17-07-2024, 02:21 PM
  Nice Era EPMB 3 flashes not recognised by control unit budda 2 2,228 16-07-2024, 08:47 AM
  nice robus D400 smartphone control YOSH 1 3,302 05-03-2024, 04:45 PM
  Nice MC800 Wiring issue Adamzsite 2 3,192 05-03-2024, 04:37 PM
  nice robus troubleshooting tarmongaidon 7 25,677 30-01-2024, 05:19 PM
Last Post: hasanova
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 4,717 04-01-2024, 10:06 AM
  Nice Robus RBA3c Wifi Relay Switch Wiring denis 1 3,912 01-11-2023, 09:45 AM
