  • 268 Vote(s) - 2.79 Average
140 degree automated gates
I have a query.
we want a set of gates to open to 140 degree we do not want to use underground gate rams. We want to use spider rams which open to 110 degree. IF we offset the spider rams further away from the gate post will we be able to get them to open to 140degree if we offset them in the correct place.
regards
lewis
(25-01-2013, 06:06 PM)firehelm100 Wrote: I have a query.
regards
lewis
I don't think there is an Arm Available that will give you an opening much more than 110 degrees. The Only solution for 140 degree opening would be Underground motors.
As an arm Pivots and the Geometry determines the angles that can be achieved it is very important you do not fit an arm outside its recommended geometry. This will cause damage to the arm and brackets as the arm will be pushing and pulling beyond its limits and in theory will be fighting against itself. The Max you can usually get with any Arm type automation is 120 degrees.
Hope this has helped with your questions
regards
lewis
Hey, Thank you for your reply. We have now found a solution which means we can open to 130 degrees using articulated electric gates. There is a system specificly designed for wide angles.
But thank you for your input.
Kind Regards
Lewis
  FAAC gates out of sync TheDock 1 1,317 21-08-2024, 12:21 PM
Last Post: TheDock
  Rigel 5 , gates won't open Nameloc 4 6,273 04-05-2024, 12:41 PM
  Gates tripped Phil.c 3 2,552 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 1,359 18-02-2024, 06:29 PM
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 4,528 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 11,156 07-01-2024, 07:11 PM
Last Post: Simon NW
  Nice Gates not closing StuL 1 4,403 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 12,171 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Came gates stuck open. Ring8180 7 23,261 23-02-2023, 01:08 PM
  Aria 400 - gates keep opening and closing objohnuk 1 5,702 13-04-2022, 11:32 AM
