  • 14 Vote(s) - 3.57 Average
BFT Rigel 6 - Buttons suddenly stop working
Morning!
The buttons on my Rigel6 have suddenly stopped working. I've checked the connections for power (50/51) and I can see wires plugged into 60+61 and 60+64. I'm assuming 64 are the two gate buttons and 61 are the ground loops. When I open the board the letters PED are showing on the LCD display.
My question is - if there is an issue with a particular pin on the board (61 for example) can I relocate the connections in 61 to 64 with no ill effects or will this affect the programming on the board? I assume 64 normally issues the PED command which the board is configured for opening a single gate and attaching to 61 will open both gates.
Cheers,
Rob
(10-10-2022, 09:25 AM)RobE Wrote: Morning!
Cheers,
Rob
thanks for the message,
if you are using other pins on the board there is not an issue doing this however, the logic on the board will need to be reconfigured via the logic settings.
Many Thanks
Appreciate the reply, thank you.
So I could move to 61 (which defaults to StartE) and I can reprogram that. Got it. Thank you.
Also, just thinking about it. As the board constantly shows PED on LCD, could that be a short somewhere in the gate buttons that are causing the PED command to be issued and it's just shut down?
(10-10-2022, 10:33 AM)RobE Wrote: Appreciate the reply, thank you.
Hi Rob,
PED is pedestrian input activated. This means that whatever you have wired into the PED input is shorting to give it a constant command.
Kindest Regards,
Sam - I read this and then took one of the buttons off. It dumped a load of water on the floor. Problem solved. Thank you to you both. Smile
(10-10-2022, 12:59 PM)RobE Wrote: Sam - I read this and then took one of the buttons off. It dumped a load of water on the floor. Problem solved. Thank you to you both. Smile
No Problem Rob.
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 99,069 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Rigel 5 Talonfinger 0 1,042 26-03-2025, 12:07 PM
Last Post: Talonfinger
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 1,751 03-02-2025, 11:29 AM
  BFT Rigel 5 - Phot message robs999 2 2,899 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 3,051 30-10-2024, 12:54 PM
Last Post: Vaf888
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 2,985 15-10-2024, 10:37 AM
  Gate radio receiver not working Zhymke 0 1,798 23-05-2024, 06:35 PM
Last Post: Zhymke
  BFT Rigel 5 issue Adamit 0 1,669 17-05-2024, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 16,249 04-05-2024, 12:47 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 3,910 04-01-2024, 10:21 AM
