  • 3 Vote(s) - 2.33 Average
Latch open with Videx GSM
I have a newly installed FAAC/Genius setup with a Videx GSM panel used as an intercom / call to open. (Motor: Diablo, Controller: Brain)
The Videx unit was previously used with on a BFT installation where I could text the unit and it could be permanently "latched" open, eg: 1234RLA
When the latch sequence is sent to the FAAC installation the gate opens but then closes after the programmed time interval (15 seconds).
Any input appreciated
Dave
(30-08-2022, 10:29 AM)DP86 Wrote: Hi,
Dave
Hi Dave,
thanks for the message,
can you confirm the model number of the keypad, it should be situated on the back of the keypad module itself as i can advise from here, do you know your engineers/programming code?
Kind Regards
Morning Joe,
Its a 4810N-1, yep have the programming code and access to the panel via the programming software.
Tks
Dave
Hi Dave,
The relay time can be from 01 – 99 seconds or latching (Set the relay time to 00 for latched mode. In latch mode, the relay will stay energised until the command is send again)
1111RLTnn Store the time nn = time in seconds
1111RLTnn? Store the time nn = time in seconds. Also send a confirmation text back to the sender.
1111RLT? Query the current stored time. A text message will be sent to the sender showing the stored time
Mike
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 1 1,547 12-08-2024, 03:52 PM
  Gate continues trying to open tjtj6554 1 5,928 20-09-2022, 08:02 AM
  Gates open /won't close mag1173 0 8,186 09-07-2016, 03:46 PM
Last Post: mag1173
  415 24V Forced open by rolling car mpit 1 12,415 01-09-2014, 08:10 AM
Last Post: thm
