  • 3 Vote(s) - 1 Average
Bft gate one door stopping
Hello.  I have a pair of gates bft. Motors under the  ground.  One of my gates seem to stop mid way.  The other one is fine.if I gently push it.  It will carry on to close or open.  I've checked the motor and it seems dry and not water damaged.  Been in operation for 12 years now.   Am I right in saying it's the motor needs replacing ?  Just got worn out.
Many thanks in advance.
(12-04-2022, 07:52 PM)Matty c Wrote: Hello.  I have a pair of gates bft. Motors under the  ground.  One of my gates seem to stop mid way.  The other one is fine.if I gently push it.  It will carry on to close or open.  I've checked the motor and it seems dry and not water damaged.  Been in operation for 12 years now.   Am I right in saying it's the motor needs replacing ?  Just got worn out.
Hi Matty,
Thanks for the email,
There are two likely explanations for your issue, one could be if this is a 230v system it could be that the capacitor is on its way out and would likely need replacing, a way of testing this would be to switch over the capacitor and test the motor to see if the fault persists, another plausible issue could be that the motor force on this leaf is not set high enough.
Kind Regards
Hi Matty,
Kind Regards
[quote pid="16553" dateline="1649846569"]
Thanks Joe.   It is a 240 system.    I havnt changed the motor force setting and has been the same for  years and has work faultlessly.   I reckon it must be the capacitor.   Many thanks for your help. Matty
[/quote]
Hi Matty,
Kind Regards
[/quote]
Hi Matty,
Thanks for your response, glad to hear we could be of assistance.
Kind regards,
  Gate not closing thronetm 0 132 16-11-2024, 09:25 PM
  Gate kit recommendation electric gate harry 0 802 10-09-2024, 03:57 PM
  Recommended automatic gate opener? drewdavis 0 1,119 28-08-2024, 05:13 AM
Last Post: drewdavis
  Trying to identify this Gate Controller - HOCHE UC109? RossAM 0 1,305 02-08-2024, 04:47 PM
Last Post: RossAM
  Not Able To Access Data of Sensor Gate hugheshaven 0 1,749 19-06-2024, 10:57 AM
Last Post: hugheshaven
  Gate mobile phone ‘relay’ jam_rs 1 2,470 13-05-2024, 02:37 PM
  Nice MC824H gate stuck open Markp80 1 2,513 13-05-2024, 02:32 PM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 28 26,996 10-05-2024, 08:27 PM
Last Post: Nemen3242
  Holding the Gate Open mgb 1 5,796 11-07-2023, 01:35 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 5,714 03-07-2023, 08:54 AM
