  • 48 Vote(s) - 2.77 Average
are they still working?
RE: BFT Rigel 5--how to set swing gate slow close at end ? - by JoeF - 29-07-2019, 10:52 AM
  BFT Gate Motor - Not working elyoussef.ali 1 6,082 11-09-2025, 10:15 AM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 1,783 11-08-2025, 04:12 PM
  BFT Rigel 5 Talonfinger 0 1,982 26-03-2025, 12:07 PM
Last Post: Talonfinger
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 3,784 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,217 03-02-2025, 11:29 AM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,440 04-11-2024, 05:59 PM
  BFT Rigel 5 - Phot message robs999 2 4,591 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 4,810 30-10-2024, 12:54 PM
Last Post: Vaf888
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 4,918 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,484 17-07-2024, 02:24 PM
