  • 50 Vote(s) - 2.92 Average
Swing Gate arm not moving!
(13-02-2019, 02:55 PM)Stacker Wrote: How do you make sure that the voltage is supplied to the motors after pressing remote control btw?
Can you hear your motor moving but it isnt engaging the drive shaft?
If so check your capacitors.
To also check your voltage you would need a Voltmeter.
If not possible look for signs of power Ie. LED's or some sort of movement.
Also check your panel and remove anything from the stop input to see if it works then if it does there is a fault in this input whether it be a short in the cable or so fourth.
Swing Gate arm not moving! - by a64664137 - 09-01-2019, 03:59 PM
RE: Swing Gate arm not moving! - by a64664137 - 10-01-2019, 01:20 AM
RE: Swing Gate arm not moving! - by Automatic-TC - 18-01-2019, 11:31 PM
RE: Swing Gate arm not moving! - by Stacker - 13-02-2019, 02:55 PM
RE: Swing Gate arm not moving! - by JoeF - 19-03-2019, 12:50 PM
  BFT swing gates pushing closed instead opening Marc 0 3,494 08-09-2024, 06:33 PM
Last Post: Marc
  Gate sensors does not work when raining vanbinh 5 21,237 14-06-2024, 12:13 PM
  Could Someone Give me Seeking Advice on Gate Installation for Home Security? tysonzach 0 3,167 13-05-2024, 06:49 AM
Last Post: tysonzach
  nice gate openers John Thorpe 1 9,896 19-08-2022, 03:14 PM
  CB11 gate opener testing me!!!! lou trudge 0 7,910 22-12-2021, 10:40 AM
Last Post: lou trudge
  Gate Rail Sweeper/Brush Privateersman 0 9,392 10-02-2020, 03:50 PM
Last Post: Privateersman
  GIBIDI gate motor closing problem davidcunningham 0 11,603 26-04-2019, 08:20 PM
Last Post: davidcunningham
  Help identifying electric gate fob Nick180582 5 29,931 22-10-2017, 01:22 PM
  Diatem Gate Keypad - removing cover hazel.luskin@gmail.com 0 9,352 20-05-2016, 11:28 AM
  electric gate servicing sparkey0151 1 15,861 02-07-2015, 12:57 PM
