  • 116 Vote(s) - 2.93 Average
Wg20 leaf close sync issues
Hello,
If the leafs of your gate are not closing in the correct order, swap the M1 and M2 terminal blocks over. The leaf that is closing last causing the issue will then close first.
If you are experiencing a reverse on one of the leafs this may be that the motor has reached its limits and may be detecting an issue. Try redoing the limit search.
Wg20 leaf close sync issues - by Jayjay - 18-05-2018, 12:52 PM
RE: Wg20 leaf close sync issues - by Automatic-TC - 18-05-2018, 02:11 PM
RE: Wg20 leaf close sync issues - by Jayjay - 22-05-2018, 12:38 AM
RE: Wg20 leaf close sync issues - by RMG SECURITY - 15-07-2018, 03:28 PM
RE: Wg20 leaf close sync issues - by RyanB - 18-07-2018, 09:57 AM
  Mhouse SL1 won't close correctly Dartman 5 31,113 03-02-2023, 12:04 PM
  MHouse SL1-10 partial close NAT 5 16,811 30-05-2022, 09:15 AM
  Mhouse WG20 Alex74 1 9,857 04-02-2022, 11:05 AM
  WG20 Factory Reset ? tsmyth@iinet.net.au 1 8,386 28-09-2021, 11:01 AM
  Problem with wg20 Thanos3d 2 24,169 01-05-2017, 11:22 PM
Last Post: Thanos3d
  MHouse WG20 problem brianjclarke2 1 22,460 01-09-2016, 10:53 AM
