  • 158 Vote(s) - 3.27 Average
Scs300 jamming up CB1 control panel
Hi Steve,
Thank you for your enquiry, normally if a 230v motor hums then it is the capacitor that has failed. I would advise you to swap the capacitors over from the working motor to the motor that is jamming and see if the fault moves to the other motor. I would also advise you to reprogram the open and close limits on the board to see if that helps with the problem.
If the system was working fine for a long period of time before this motor started to cause problems then i wouldn't of thought it will be a problem with motor force. If you are going to adjust the force to the motors then you will have to pay attention to the safety on that system to make sure it meets up to date legislation to gate safety and machinery directive. Hope this is usefull information for you.
Tim
Scs300 jamming up CB1 control panel - by Steeves - 28-11-2017, 08:58 PM
RE: Scs300 jamming up CB1 control panel - by Tim - 29-11-2017, 11:01 AM
  Life electric gates control box Gates head 1 8,009 12-10-2023, 01:09 PM
  FAAC alternative control panels. chris barker 1 6,578 03-08-2022, 01:45 PM
  facc control panel E164104 manual jmondragon 2 18,426 09-12-2021, 11:51 PM
Last Post: aba gate solutions
  Access Control Professionals Lowvoltagesupply 0 7,308 07-02-2019, 11:56 PM
Last Post: Lowvoltagesupply
  Beninca motors and Control unit sergomes 2 30,982 10-12-2016, 01:18 AM
