  • 185 Vote(s) - 2.98 Average
Bft Rigel 5 Gates - Sticking when opening
(22-08-2017, 11:23 AM)TimK Wrote: Hi Danny,
Thank you for your enquiry, on the Rigel 5 boards there is an LED screen which gives you an error code, if you can take a look at that we should be able to diagnose what the problem is. All failing that can you hear a humming off the motor you are having a problem with? It could be that the capacitor has failed and the one motor isn't receiving enough start up voltage.
Tim
Hi Tim,
Thanks for getting back to me. No error code on the board. I went into the menu a couple of days ago and tried to stagger the opening of the gates to see that would help.
The lead gate opens first now by a second or two, however - it'll open a little and stop. This is obviously what was happening before only straight away.
If I lower the torque, the lead gate opens more reliably but seems to lose power at 70% open and stops unless you give it a push to open all the way.
If you increase the torque the gate opens fine, but you have the problem of it stopping when it starts opening much more often. If you've go it past it stopping it'll open and close every time reliably until you leave it for a few hours and it'll go back to stopping.
Does it sound like it might be a faulty motor?
RE: Bft Rigel 5 Gates - Sticking when opening - by dannys1 - 22-08-2017, 11:32 AM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 101,968 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Rigel 5 Talonfinger 0 2,072 26-03-2025, 12:07 PM
Last Post: Talonfinger
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,362 03-02-2025, 11:29 AM
  BFT Rigel 5 - Phot message robs999 2 4,752 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 5,025 30-10-2024, 12:54 PM
Last Post: Vaf888
  BFT Sliding Gate randomly opening and closing AdrianMate 5 11,529 14-06-2024, 12:12 PM
  Two BFT pairs of electric gates (one remote) Harry44 1 4,273 04-06-2024, 01:30 PM
  BFT Rigel 5 issue Adamit 0 2,736 17-05-2024, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 17,967 04-05-2024, 12:47 PM
Last Post: Alee
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,251 04-01-2024, 10:21 AM
