  • 211 Vote(s) - 3.15 Average
Bft Ares Gate not closing
(04-07-2017, 09:30 AM)TimK Wrote: Hi Hatbat,
There are a few thing i would check, first of all i would check that there is nothing covering the lens inside the photocell covers like insects or dust which could be blocking the beam. If these are clean and you are still having problems with the gates stopping in the open position i would do a continuity test of the cables from the board to the photocells to make sure there are no breaks. Hope this helps.
Tim
Hi Tim,
Thanks for your reply. I have checked the photocell covers - all looks fine.
Is a power supply of 3.3V going to the Tx and Rx sufficient? The photocells work fine in the office connected to a power supply (relay toggles and output changes as expected) but not in situ - even if I put the Tx within 4" of the Rx to see if I can hear the relays work.
Hatbat
Bft Ares Gate not closing - by Hatbat - 03-07-2017, 11:25 PM
RE: Bft Ares Gate not closing - by Tim - 04-07-2017, 09:30 AM
RE: Bft Ares Gate not closing - by Hatbat - 04-07-2017, 09:40 AM
RE: Bft Ares Gate not closing - by Hatbat - 05-07-2017, 12:52 PM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 2,156 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,426 21-07-2025, 06:54 AM
Last Post: jojo351
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,713 04-11-2024, 05:59 PM
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,390 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,911 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,051 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 3,125 23-05-2024, 06:35 PM
Last Post: Zhymke
  Gate wont close issue MR_ROBOT 3 17,269 11-04-2024, 08:08 AM
