  • 173 Vote(s) - 2.73 Average
Strange Gate Opening Issue
(06-06-2017, 11:54 AM)scottc Wrote:
(03-06-2017, 01:50 PM)Automatic-TC Wrote:
(02-06-2017, 12:02 PM)scottc Wrote: Hi All,
I would be most grateful for your advice. My Dad has a BFT ELI 250 Kit, opening two gates. They have been working fine of late, but on Tuesday a strange issue arose.
My parents went out for the afternoon, opening the gates ok and watched them close fully after leaving. When they returned home, they found one side of the gates to be open. On using the remote to open the other side of the gates, the button which opens both gates did not appear to be working. They tried a second remote and the open swtich in the house, but the second gate would not open. A second button on the remote operates one side of the gate only (the side that was already open), and this appears to work ok.
I had a look at the control box yesterday (I have studied electronics previously) and was confused with what I found. When the second button on the remotes were pressed (I tried all three remotes for the system), the relays switched to allow the one side of the game to open, and the LED on the receiver unit flashed to show receipt of the remote signal. However, the first button on the remote did not do anything to the control unit, no LED flashing to indicate the signal received, or no relays switching. I checked all of the on-board fuses, and these were fine. No other obvious signs of components burnt out, all wires attached ok etc. I cannot see any obvious issue why the button for both gates will not work, same with the open switch inside the house.
Does anyone have any ideas?
Many thanks!
did you check voltage on engine output ??
i mean press the transmitter and check terminal output for engine .
be carefull with this !!!!!! or call electrician for help
Hi, thanks for the email.
I've checked the voltage on both terminals when the buttons are pressed. When button two is pressed, voltage is applied to the single gate terminal only. When button 1 is pressed, no voltage is detected on either gate terminal. Both should be live, but they aren't.
This applied to all remotes and the manual gate opening switch in the house.
is this gate operator set are 24 V ?
did you check all fuses on control board
Best RegardsĀ
TomĀ
Strange Gate Opening Issue - by scottc - 02-06-2017, 12:02 PM
RE: Strange Gate Opening Issue - by Automatic-TC - 03-06-2017, 01:50 PM
RE: Strange Gate Opening Issue - by scottc - 06-06-2017, 11:54 AM
RE: Strange Gate Opening Issue - by Automatic-TC - 07-06-2017, 06:44 PM
RE: Strange Gate Opening Issue - by scottc - 09-06-2017, 08:53 AM
RE: Strange Gate Opening Issue - by Automatic-TC - 09-06-2017, 03:41 PM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 2,155 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,426 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,229 03-02-2025, 12:24 PM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,711 04-11-2024, 05:59 PM
Last Post: Sootylfc
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,390 15-10-2024, 10:37 AM
Last Post: Sootylfc
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,910 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,051 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 3,125 23-05-2024, 06:35 PM
Last Post: Zhymke
  BFT Rigel 5 issue Adamit 0 2,889 17-05-2024, 10:28 AM
Last Post: Adamit
