  • 173 Vote(s) - 2.73 Average
Strange Gate Opening Issue
(02-06-2017, 12:02 PM)scottc Wrote: Hi All,
I would be most grateful for your advice. My Dad has a BFT ELI 250 Kit, opening two gates. They have been working fine of late, but on Tuesday a strange issue arose.
My parents went out for the afternoon, opening the gates ok and watched them close fully after leaving. When they returned home, they found one side of the gates to be open. On using the remote to open the other side of the gates, the button which opens both gates did not appear to be working. They tried a second remote and the open swtich in the house, but the second gate would not open. A second button on the remote operates one side of the gate only (the side that was already open), and this appears to work ok.
I had a look at the control box yesterday (I have studied electronics previously) and was confused with what I found. When the second button on the remotes were pressed (I tried all three remotes for the system), the relays switched to allow the one side of the game to open, and the LED on the receiver unit flashed to show receipt of the remote signal. However, the first button on the remote did not do anything to the control unit, no LED flashing to indicate the signal received, or no relays switching. I checked all of the on-board fuses, and these were fine. No other obvious signs of components burnt out, all wires attached ok etc. I cannot see any obvious issue why the button for both gates will not work, same with the open switch inside the house.
Does anyone have any ideas?
Many thanks!
did you check voltage on engine output ??
i mean press the transmitter and check terminal output for engine .
be carefull with this !!!!!! or call electrician for help
Best RegardsĀ
TomĀ
Strange Gate Opening Issue - by scottc - 02-06-2017, 12:02 PM
RE: Strange Gate Opening Issue - by Automatic-TC - 03-06-2017, 01:50 PM
RE: Strange Gate Opening Issue - by scottc - 06-06-2017, 11:54 AM
RE: Strange Gate Opening Issue - by Automatic-TC - 07-06-2017, 06:44 PM
RE: Strange Gate Opening Issue - by scottc - 09-06-2017, 08:53 AM
RE: Strange Gate Opening Issue - by Automatic-TC - 09-06-2017, 03:41 PM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 2,154 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,425 21-07-2025, 06:54 AM
Last Post: jojo351
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,711 04-11-2024, 05:59 PM
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,389 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,909 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,050 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 3,125 23-05-2024, 06:35 PM
Last Post: Zhymke
  BFT Rigel 5 issue Adamit 0 2,888 17-05-2024, 10:28 AM
Last Post: Adamit
