  • 214 Vote(s) - 2.91 Average
BFT Deimos gate won't close
#10
(03-05-2017, 06:12 PM)MrDiagnostics Wrote: Hi Arthur,
The photo warning normally only comes up where there is a fault with the photocells, I would look at changing them, if your certain the wiring to the photocells are ok.
Do you know how to test wiring for a open/short circuit?
Do you mean the code SWC code came up, rather than what you mentioned below SUC? SWC would be the correct code. If this is coming up when you have linked out the photocells, then change the photocells mate as they are causing the problem.
Let me know how you get on.
Hi PAJ,
Thanks for your reply. Could you please advise me on the best way to test wiring for a open/short circuit?
I've used a wire to link between connection (21 Common - 24 Photobeam).
When I linked 21 and 24 (photo beam), the display code which shows was "Suc" code, definitely not SWC code. Does this "Suc" code means there is a fault with the photocells?
I've open the covers of the two photocells and checked that there weren't any loose connections with the circuit boards.
The circuit board of the photocell which shown that it's "Centurion" brand and "Input voltage 12v - 30v AC or DC".
My gate can be open without any problem. But when I tried to close it, the gate reached at about halfway point, then it suddenly stopped, as if there was something blocked the photocells. There was an error code "Anp" which was showed and then following with an error code "Phot" that was showed on the board.
Any suggestions on how to fix the error codes "Anp" and "Phot" and close the gate fully?
Thanks,
Arthur
BFT Deimos gate won't close - by Arthur_k99 - 28-04-2017, 12:38 PM
RE: BFT Deimos gate won't close - by Automatic-TC - 29-04-2017, 01:04 PM
RE: BFT Deimos gate won't close - by Arthur_k99 - 30-04-2017, 06:17 AM
RE: BFT Deimos gate won't close - by Automatic-TC - 30-04-2017, 12:05 PM
RE: BFT Deimos gate won't close - by Arthur_k99 - 02-05-2017, 01:10 PM
RE: BFT Deimos gate won't close - by Arthur_k99 - 05-05-2017, 01:00 PM
RE: BFT Deimos gate won't close - by Arthur_k99 - 08-05-2017, 03:28 PM
RE: BFT Deimos gate won't close - by Arthur_k99 - 29-06-2017, 01:23 PM
RE: BFT Deimos gate won't close - by Arthur_k99 - 02-05-2017, 01:12 PM
RE: BFT Deimos gate won't close - by Arthur_k99 - 03-07-2017, 02:58 PM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 2,155 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,426 21-07-2025, 06:54 AM
Last Post: jojo351
  Question BFT Deimos A400 Makaroni 2 4,923 07-05-2025, 05:58 AM
Last Post: OnionBobo
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,229 03-02-2025, 12:24 PM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,711 04-11-2024, 05:59 PM
Last Post: Sootylfc
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,390 15-10-2024, 10:37 AM
Last Post: Sootylfc
  bft deimos ultra bt600 error f1 pfloyd 4 8,426 04-10-2024, 03:36 PM
Last Post: pfloyd
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,910 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,051 14-06-2024, 12:12 PM
