  • 259 Vote(s) - 2.98 Average
D5131GB FAULT
the easiest way to chek where is the problem . You have to lokalize wchih pairs of wire is a signal one .If that signal is pottential free(coming from relay ) you can try manuali just cross two wires together for short period of time (1s) just to see if gate will start .
how long thr signal wire is ? over 50m long ?
(08-01-2017, 12:49 PM)Automatic-TC Wrote: hi
if you have ohm meter you should check rezistanca in that wire ,have to by about 1 ohm ,to check this you have disconect wire frome both side ,after cross one side (end) and conect the meter parallel
Best RegardsĀ
TomĀ
D5131GB FAULT - by Carlo - 08-09-2015, 08:20 PM
RE: D5131GB FAULT - by Doon1968 - 01-10-2015, 09:12 AM
RE: D5131GB FAULT - by Carlo - 01-10-2015, 10:04 AM
RE: D5131GB FAULT - by Carlo - 07-01-2017, 04:06 PM
RE: D5131GB FAULT - by Automatic-TC - 08-01-2017, 12:49 PM
RE: D5131GB FAULT - by Carlo - 08-01-2017, 01:53 PM
RE: D5131GB FAULT - by Access-Control-Ltd - 08-01-2017, 01:54 PM
RE: D5131GB FAULT - by Carlo - 08-01-2017, 05:15 PM
RE: D5131GB FAULT - by Carlo - 08-01-2017, 02:00 PM
RE: D5131GB FAULT - by Access-Control-Ltd - 08-01-2017, 03:42 PM
RE: D5131GB FAULT - by Access-Control-Ltd - 08-01-2017, 05:23 PM
  Lost signal for handsets DAITEM D5131GB Carlo 1 14,352 09-12-2021, 11:46 PM
Last Post: aba gate solutions
  PROTECO Q60S/R FAULT AND INSTALL jeffducati 11 82,754 18-06-2012, 09:58 AM
Last Post: Proteco_UK
