  • 255 Vote(s) - 2.83 Average
Genius 452/455 Learning Issue
(18-12-2016, 03:15 PM)Automatic-TC Wrote: hi
is that 452 mps ? control board
you can press button board for 3 sec and after when gate move on using transmitter to program all steps separately .1.normal open speed,2. slowmotion open,3stop,4close normal speed,5slowmotion closing,and 6stop
I believe it is the 452 board.
I have played about with it for ages today and did indeed go into the advanced learning mode but was a little unsure of how to program it in this mode.
I dont have a transmitter so am doing it with a piece of wire from the Open A terminal through a push button switch to 0V.
If I hold in the button for 3 secs the gate opens and DL10 flashes. When the gate opens fully and touches the ridged stop plate what do I do? i am assuming you press 3 times to stop? Then leave a Open delay then give it 4 pulses to close and then 6 to stop again??
I managed to get the gate to close again using this learning mode but the DL10 led was still constantly lit and I cannot seem to exit the mode to try the gate opening that I have programmed?
Sorry i am a bit of a novice at this?
Genius 452/455 Learning Issue - by Robedj - 18-12-2016, 01:50 PM
RE: Genius 452/455 Learning Issue - by Robedj - 18-12-2016, 10:22 PM
RE: Genius 452/455 Learning Issue - by Robedj - 27-12-2016, 05:08 PM
RE: Genius 452/455 Learning Issue - by Robedj - 02-01-2017, 06:44 PM
RE: Genius 452/455 Learning Issue - by Robedj - 03-01-2017, 10:27 AM
RE: Genius 452/455 Learning Issue - by Robedj - 06-02-2017, 09:37 PM
  BFT Demios A600 bAr issue Rohbot15 2 2,092 15-08-2025, 01:41 PM
  BFT Deimos issue erickavo 2 3,095 09-07-2025, 11:34 AM
  Genius JA592 issue fintaneduffy 3 5,854 19-01-2024, 09:58 AM
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 5,926 25-05-2023, 03:55 PM
Last Post: Kaala1
  BFT IGEA BT issue warren5 1 5,778 13-04-2022, 11:49 AM
  Genius Brain 17 Control Board - External Open/Close Signal rhennessysummit 1 8,610 02-05-2021, 09:00 PM
Last Post: soother
  Beninca BOB21m Photo cell issue Rossm1987 1 7,812 02-05-2021, 12:39 PM
Last Post: Rossm1987
  BFT C130 Photocell Issue labbetts 0 5,982 25-01-2020, 05:01 PM
Last Post: labbetts
  BFT DEIMOS BT Programming issue dawoodejaz@hotmail.com 0 6,538 28-11-2019, 12:11 AM
  Genius Gate System Problem grasshopper 1 14,824 01-07-2019, 09:39 AM
