  • 316 Vote(s) - 2.81 Average
Chamberlain motor lift 5000 remotes and keyless pad not opening door
Hi Peter,
Glad to hear that!
If you do require any additional support, do not hesitate to contact me.
(15-05-2016, 08:36 PM)Peter Wrote:
(13-05-2016, 10:46 AM)Sav Wrote: Hi,
I have seen this before the receiver built into the logic board has failed which has stopped all radio transmission. If you put a cable between 1 & 2 the motor will still work. All radio transmission will not.
Does your remotes work on a 418mhz or 433mhz?
Thanks for the reply Sav but i've managed to reset it now as I noticed that the keyless pad numbers lit again so I tried the re- set procedure and now the remotes are also working too!
Peter
RE: Chamberlain motor lift 5000 remotes and keyless pad not opening door - by Sav - 17-05-2016, 09:39 AM
