  • 229 Vote(s) - 3.2 Average
Chamberlain Evolution not successfully opening door
Usually a force reversal points to a few different possible problems.
1. When you put the door in the half way position does it drop or retract?
2. How difficult is it to move the door by hand?
3. Where are the springs on the garage door themselves?
(16-05-2016, 10:29 PM)Rephlex Wrote: I have just purchased and fitted a Chamberlain ML700EV kit. This is for a single GRP retractable door. Previously it was fitted by the house builder with a Beidi Intelligent 800 device, which konked out after 5 years.
I was able to re-use the mounting points on the lintel and the top of the door, so the kit was easy to install.
I tightened the spring on the toothed belt until the socket would no longer grip the nut because of the exposed thread. This seems to be around "halfway" as per the video and the belt is under good tension.
The door raises to about 20 degrees and then stops, I assume because it is sensing difficulty/blockage.
If I support the door with my hand, it will power past this imaginary obstruction and on to the fully open position.
Advice appreciated.
RE: Chamberlain Evolution not successfully opening door - by Sav - 17-05-2016, 09:38 AM
  Chamberlain ML1000EVGB Mearns 1 7,781 08-08-2023, 02:17 PM
  BFT garage door not opening Harry90 0 14,251 30-12-2019, 10:19 PM
Last Post: Harry90
  Swapping Hormann to Chamberlain NeilJonesOnline 0 16,582 01-08-2018, 08:16 PM
Last Post: NeilJonesOnline
  chamberlain garage door remote identification JES 0 27,263 26-10-2016, 06:51 PM
Last Post: JES
  Door opens & closes a small way jbw 1 21,916 28-02-2016, 09:52 PM
Last Post: Alimg
