  • 314 Vote(s) - 2.82 Average
Chamberlain motor lift 5000 remotes and keyless pad not opening door
(13-05-2016, 10:46 AM)Sav Wrote: Hi,
I have seen this before the receiver built into the logic board has failed which has stopped all radio transmission. If you put a cable between 1 & 2 the motor will still work. All radio transmission will not.
Does your remotes work on a 418mhz or 433mhz?
Thanks for the reply Sav but i've managed to reset it now as I noticed that the keyless pad numbers lit again so I tried the re- set procedure and now the remotes are also working too!
Peter
RE: Chamberlain motor lift 5000 remotes and keyless pad not opening door - by Peter - 15-05-2016, 08:36 PM
