  • 236 Vote(s) - 2.98 Average
Motorlift ML850 Reverses on close. LED flashes 11 (!) times.
My 8-year old ML850 is starting to give me a problem where it reverses about half a second after it reaches the closed position. As it comes back up, the orange indicator light flashes 11 times which is a bit confusing as the diagnostic codes only go up to 6!
If I reset the travel limits & force, it'll behave itself for another couple of opens but then revert to opening as soon as it hits the bottom. Checked all the usual stuff, no debris, safety beam isn't being broken, no binding on guides etc. Have tried powering off the unit to reset it, then resetting travel limits & force but the problem still remains.
May just be coincidence, but it's happened just at the start of this very cold snap we're having.
Is it likely the logic board needs replacing?
Cheers,
Dan
Motorlift ML850 Reverses on close. LED flashes 11 (!) times. - by DJBenz - 17-01-2016, 02:02 PM
  Motor lift ml850 protector system rondickinson@btinternet.com 1 17,529 15-04-2019, 09:34 AM
  ML850 no longer operates rivergo1d 1 25,852 12-04-2018, 04:52 PM
Last Post: Tim
  MotorLift ML700 or 850 blows plug fuses olliecat82 2 17,566 20-11-2015, 07:20 PM
Last Post: olliecat82
  Motorlift 5000 with bad memory 71MGB 2 18,700 13-03-2014, 12:25 PM
Last Post: 71MGB
  remote will open but not close garage door Sharon OWest 4 26,736 01-08-2013, 10:38 AM
Last Post: DJBenz
  ML850 Remotes don't work huckit P 1 22,913 06-01-2012, 09:59 AM
  Chamberlain MotorLift 5000 Garage Door Opener secash 1 22,239 27-01-2011, 05:55 PM
  motorlift ML 859GB sparkymike 1 14,095 29-06-2010, 04:45 PM
  Where to buy Motorlift Garage Door Openers easygates 0 12,883 13-01-2010, 12:04 PM
  ML850. Setting the Limits Brillopad 2 29,539 03-11-2009, 02:49 PM
Last Post: Doorman
