  • 234 Vote(s) - 3.09 Average
MotorLift ML700 or 850 blows plug fuses
I believe the issue would be the motor coming to the end of its life. As you said it only blows a fuse whilst under load. The pressure at the end of the cycle may be whats causing the motor to blow the fuse. This will be down to the motor becoming faulty.
(02-11-2015, 06:59 PM)olliecat82 Wrote: Hi folks
My faithful MotorLift garage door opener keeps blowing the plug fuse at the end of either an opening or closing manouver. It had a 3A and I tried a 5A and it still blew. When I disconnect the drive and open/close the door manually the door opens and closes easily and has no obvious reasons for an extra load on the motor. I would be in your debt if you no the reason or the solution.
RE: MotorLift ML700 or 850 blows plug fuses - by Sav - 20-11-2015, 12:03 PM
  Motorlift ML850 Reverses on close. LED flashes 11 (!) times. DJBenz 2 27,689 19-01-2016, 07:10 PM
Last Post: DJBenz
  Motorlift 5000 with bad memory 71MGB 2 18,891 13-03-2014, 12:25 PM
Last Post: 71MGB
  Chamberlain MotorLift 5000 Garage Door Opener secash 1 22,408 27-01-2011, 05:55 PM
  motorlift ML 859GB sparkymike 1 14,271 29-06-2010, 04:45 PM
  Where to buy Motorlift Garage Door Openers easygates 0 13,024 13-01-2010, 12:04 PM
  chanberlain motorlift 5000 1 17,202 20-10-2009, 11:01 AM
Last Post: malito100
  MotorLift Garage Door Openers 1 17,022 28-08-2009, 04:02 PM
  ML700-GB - Rail support bracket peterworks 0 14,228 09-01-2009, 03:44 PM
Sad ML700 Skysurfer 2 17,731 06-11-2008, 09:37 PM
Last Post: Skysurfer
