  • 214 Vote(s) - 2.86 Average
Foundations
The foundations you set will be completely dependant on the structure of the ground you are allowing the gate to run across. If for instance you are on quite compact dirt which is not likely to move easily then the foundations could be more forgiving and you would not have to go down quite so deep. If however you find yourself on a loose sandy ground, then it might be wise to go that extra bit deeper to prevent any cracks or damage over time occurring to the concrete when driven over. Ideally I would say 300mm would be an appropriate depth for compact soil. If you are fitting steel posts which will support the gate, then these will need foundations running a 1/3 of the height protruding from the ground. For instance, if you have a 2m high gate, the foundation for the post would ideally need to be around a metre below the surface. Hence requiring a 3m length post.
Hope this helps.
Kinde Regards,
Dave
(01-02-2015, 05:43 PM)Broljo Wrote: I am a new member and am installing a sliding gate for the first time.As it is 200 m from the house I am hoping to use a solar charged system. Could any one give me an idea of a suitable sizes and depth for the concrete foundation? Should it have reinforcing rods included? The gate is 5.5m wide by 2.2m tall and weighs 550 kg and will run behind two stone columns of 70cm width. Any ideas most welcome. Thank you.
Dave Blake
Foundations - by Broljo - 01-02-2015, 05:43 PM
RE: Foundations - by Blakey111 - 03-02-2015, 10:58 AM
RE: Foundations - by Broljo - 03-02-2015, 03:38 PM
