  • 334 Vote(s) - 2.72 Average
Hi Brian
On the Apitech Mac2 Panel, there is not a designated earth point on the panel, so in which case you do not earth the motors back to the board itself, what you will need to do is earth the motors back to your best means of earth, ie: you may have an isolation point for your mains before it enters the panel, in which case there should be an earth in there, if your mains into the panel has an earth, you can create a junction in the panel in which you can isolate your mains earth and your motor earths, giving you earthing through out, if your require wiring diagrams for any other part i have given a link to the manual below,
Mains In is not polarity sensitive so in can be any way around but usually its
1 = +
2 = -
What colors are provided on your motor cables in which case i can tell you where to wire them in,
http://www.dieffematic.com/documenti/MACH2230multi.pdf
I hope this helps you!
(28-10-2014, 10:51 PM)brian Wrote: Hi,
I purchased this swing gate kit and need help in wiring the panel, there is a manual on ebay, but doesn't show what colour wires go to which connector number on the panel.
http://www.ebay.co.uk/itm/KIT-GATE-GATES...TM:GB:1123
I just need to know the following.
Where is Earth connection on panel?
What connector number on panel do I connect 230v input, red/live to?
What connector number on panel do I connect 230v input, Blue/Neutral to?
I have being onto supplier, but hard to get through to them in english, as there italian??
So, I hope someone can help?
Thanks in advance.
RE: Wiring control panel apritech mach2 230v - by Sav - 29-10-2014, 11:24 AM
  Wiring a maglock Solvika 0 8,025 09-03-2016, 10:46 PM
Last Post: Solvika
Last Post: Paj
Last Post: 4LPS
