  • 293 Vote(s) - 2.84 Average
LA400 DIAGNOSTIC FLASH 2
I would try disengaging the control panel and then re-engaging it using the manual release key. Once this is done, turn the save switch to the off position and power down the system completely (removing both batteries and 24V transformer input). Once powered down, reapply both batteries and transformer plugs, wait for the board to boot up and turn the save switch back to the on position.
If you're still getting a diagnostic light flashing indicating that the motor is disengaged, then try switching the motor outputs over and see if the diagnostic light changes from 2 flashes to 3 flashes. This will prove that the fault has moved with the arm and not stayed with the same motor output on the board.
I would imagine that it is just a minor glitch with the sensor on the manual release lever, but if it needs replacing, please contact us on 0845 054 5070 for a price on spare parts.
Kindest regards,
Dave
Dave Blake
LA400 DIAGNOSTIC FLASH 2 - by SAA - 09-06-2014, 07:26 PM
RE: LA400 DIAGNOSTIC FLASH 2 - by Blakey111 - 11-06-2014, 09:22 AM
  Liftmaster LA400 Defender 6 23,524 03-08-2023, 12:26 PM
Last Post: Torantrieb
  LA400 gate openers 24v Tussun 1 14,369 03-01-2014, 12:10 PM
  LYN300 Diagnostic light flashing 6 times jeff 3 20,674 02-12-2011, 12:24 PM
Last Post: Mark
  RPM Reversal Diagnostic Error on Liftmaster LYN40024 2 21,793 16-05-2011, 05:59 PM
Last Post: Guest
