  • 307 Vote(s) - 2.79 Average
RPM Reversal Diagnostic Error on Liftmaster LYN40024
(16-05-2011, 03:53 PM)Mark Wrote: Does the setup allow you to set the limits by holding the direction buttons or does it move a few inches then stop during the limit setup ? If it does then RPM sensor is gone in the motor most likely due to wires being shorted. If Not then most likely brackets are incorrect and arm has strained the gears inside causing it to fight against itself.
The setup allow me to set the limits by holding the direction buttons with no problem and the limits are set propoerly. However, after saving, either on closing or opening the gate will not stop and bounce back and give the RPM reversal error. Sometimes after trying a few times, the limits will not be set and i have to disconnect the system for a good number of hours and try it again, then the limit will be set but the gate will not work properly. Please advise what else i can do.
Mark, the setup allow me to set the limits by holding the direction buttons with no problem and the limits are set properly. However, after saving, either on closing or opening the gate will not stop and bounce back and give the RPM reversal error. Sometimes after trying a few times, the limits will not be set at all and i have to disconnect the system for a good number of hours and try it again, then the limit will be set but the gate will still not work properly and both closing and opening speed get very slow. What i am doing currently until i can resolve this problem is to manually stop the gate with the remote before it reaches the limit. In addition, does the arm needs to be oiled or greased? Please advise what else i can do.
RE: RPM Reversal Diagnostic Error on Liftmaster LYN40024 - by Guest - 16-05-2011, 05:59 PM
  LiftMaster SL400EVK & 722e Failsafe Tucks27 4 1,716 26-11-2025, 10:52 AM
  Liftmaster MYQ Internet gateway koen_dc 4 28,155 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  Liftmaster LA400 Defender 6 23,528 03-08-2023, 12:26 PM
Last Post: Torantrieb
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 20,154 09-03-2021, 02:46 PM
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 24,205 22-02-2021, 08:48 PM
Last Post: russ
  Liftmaster CB1 gates started to open themselves telnet123 4 36,381 01-01-2020, 09:43 AM
Last Post: pronosoft
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 36,134 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  Liftmaster sliding gate Kar1e 1 20,477 08-08-2017, 11:23 AM
  Liftmaster SCS300K - stop/go mtuk100 1 18,934 18-04-2017, 09:31 AM
