  • 277 Vote(s) - 2.92 Average
ICARO + LEO B CBB : Open gate at certain times?
(16-01-2014, 08:27 PM)tommysharp Wrote: Just wondering if it'd be possible to open the gate for certain times of the day say 9am to 5pm Mon-Fri? Didn't see anything in the manual but maybe someone has some smart ideas?
My next thought is to hook it up to a z-wave home automation system to do this and a few other things....
The following is a "universal" solution that applies to most gate automations:
You can connect the output of a timer in series with the closing photocells (not applicable in case of BUS photocells). The output of the timer must be a dry contact which remains closed all day except for, say, 9am to 5pm when it stays open. When the contact is closed the control-board works as usual. When the contact is open the contol-board is tricked into believing that the closing photocells report the presence of an obstacle leading in the operator not closing. During this period, the first time (if at all) that someone commands opening of the gate, the gate will open and stay open. Obviously, if nobody opens the gate (ie during weekends, holidays or early in the morning if everybody arrives late) nothing happens and the gate stays as is (closed). For the same reason, you only need a simple daily programmable timer, though a timer with automatic daylight savings adjustment is preferable. It is advisable to also install a key-switch (not key-button) in parallel with the timer output so that you can bypass it (avoiding holding the gate open).
RE: ICARO + LEO B CBB : Open gate at certain times? - by thm - 17-01-2014, 12:48 PM
  BFT Gate Motor - Not working elyoussef.ali 1 6,390 11-09-2025, 10:15 AM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 2,151 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,424 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,228 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,570 03-02-2025, 11:29 AM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,710 04-11-2024, 05:59 PM
Last Post: Sootylfc
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,389 15-10-2024, 10:37 AM
Last Post: Sootylfc
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,909 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,045 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 3,124 23-05-2024, 06:35 PM
Last Post: Zhymke
