  • 331 Vote(s) - 3.03 Average
BFT Sub first gate slow to open
A few easy checks will sort out the problem for you,
Can you see any oil leak? if so you will need to purchase a oil seal kit and fit it, messy and time consuming
if not any leaks;
Manual release the unit
slowly push the gate to the open position
unscrew the filler cap on the unit
there should be visible oil near the top (the oil goes down when the gate is closed)
top up if needed
reassemble the unit
run the gate a few times to bleed any air out of the system
all should be ok now
BFT Sub first gate slow to open - by martin100 - 13-08-2013, 10:55 PM
RE: BFT Sub first gate slow to open - by baz5464 - 15-08-2013, 04:58 PM
  BFT Gate Motor - Not working elyoussef.ali 1 6,390 11-09-2025, 10:15 AM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 2,151 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,424 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,228 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,570 03-02-2025, 11:29 AM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,710 04-11-2024, 05:59 PM
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,388 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,909 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,044 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 3,124 23-05-2024, 06:35 PM
Last Post: Zhymke
