  • 431 Vote(s) - 2.94 Average
Frog p 230v or 24v ?
Thanks for your advice, my gates are only about 1.8 m wide and 1.6 high and although a fully clad gate there will be approx 450mm of balustrade design on the top so I would think from a wind point of view I would be ok using motors with the encoders.
As I understand it the came frog p kit has just about all I need in a kit with the exception of the magnet lock and intercom system. If you can give me a quote on the frog p kit I would be grateful.
Can you give me some info on cable type and size I should run for the supply to the gates and also do you know if CAT5E cable is the correct type for an intercom with video screen in house only but with a number pad on the outside to use for entry.
I was told that you should not run cat5 in the same ducting as your supply cable, is this true?
Thanks again.
Frog p 230v or 24v ? - by Emilyjudy - 03-02-2013, 07:09 PM
RE: Frog p 230v or 24v ? - by Blakey111 - 04-02-2013, 05:24 PM
RE: Frog p 230v or 24v ? - by Emilyjudy - 10-02-2013, 03:58 PM
RE: Frog p 230v or 24v ? - by Rosie1234 - 20-02-2013, 03:55 PM
RE: Frog p 230v or 24v ? - by velinda - 06-03-2014, 10:05 PM
RE: Frog p 230v or 24v ? - by stephen70 - 08-03-2014, 01:32 AM
Last Post: nuphor
  CAME Frog AE-p24 kit Push Button Stuartl 2 7,504 20-10-2023, 08:57 PM
Last Post: Stuartl
  Frog A24E motor stopping SW1806 7 16,747 24-03-2023, 02:58 PM
  Came FROG-A + ZA3 controller > gates wont close safety beam endam 6 18,045 23-02-2023, 01:09 PM
  Came FROG A noisy fezster 1 7,990 30-09-2022, 03:16 PM
  Came FROG - one leaf occasionally does not open fezster 3 13,285 03-08-2021, 10:07 AM
  Came ZM3E and Frog Motors both opening on M1 not seperately giuseppem 1 18,808 11-04-2018, 07:25 AM
  Frog - ZA3: gates won't open BarryD 0 12,101 15-06-2016, 01:34 PM
Last Post: BarryD
  CAME Frog and Daitem 902 jderuk 1 22,092 08-03-2014, 01:17 AM
Last Post: stephen70
